Thank you very much
1998 Toyota Corolla Temp Gauge Pegs
Thank you very much
Pressure test the cooling system to eliminate that as a cause. Hook up a scanner to see what the ECM is reading as the coolant temp.
However, if you have the capability of doing it then you should be able to use most any diode.
I just did a Google search for 3 volt zener diode and this came up.
https://www.amazon.com/3-volt-zener-diode/s?k=3+volt+zener+diode
Clearly you can source them from other places but they are out there.
I am posting a couple guides that I doubt you need but others may visit this page just like you did that may need a little more info on testing these types of circuits.
Please let us know how you make out with this and let us know if you have other questions. Plus you never, know that this person may respond. I would think not as it is almost 15 years old but you never know.
Thanks
Thanks again.
Thanks for this info so far. If this is successful, I am sure others will benefit from this in the future. Thanks again.
Suggested Repair
The engine is not actually overheating: the sender was replaced and resistance-checked, and an OBD reading confirms normal coolant temperature with no cooling-system leak. The temperature gauge itself is the likely fault. The approved repair is to replace the gauge or cluster. Someone comfortable soldering may try replacing the roughly 3V zener diode on the gauge, but that is not a Toyota-approved repair and was not confirmed as successful.
Conversation Summary
A Toyota Corolla temperature gauge climbed past full scale within seconds of ignition even after the temperature sender was replaced. An expert suggested a bad gauge, a cooling-system pressure test, and comparing the ECM coolant-temperature reading. The owner found no leak and suspected a nearly shorted 3V zener diode on the gauge. A later owner of a 1998 Corolla had the same symptom, confirmed with an OBD reader that the engine was not overheating, and verified the sender. The expert said Toyota would replace the whole gauge rather than the diode, but a capable person could try a commonly available 3V zener and report the result.
