2000 Toyota Corolla Loses Power
RITESHGHODY
Toyota Corolla CE 2000, 120,000 miles. The check engine light showed up at around 98,000 miles and I ignored it and reset it by unplugging the batteries. Then just recently the engine light showed up again and went away on its own. and a couple of days back when I was driving on a freeway I floored the acclerator as somebody was tailgating me the engine the car refused to acclerate. it was a leveled road, no uphill. Now it is running just fine, could it be the catalytic convertor or is it the fuel pump dying on me ?
Apr 6, 2006 at 6:37 AM
LOSONE
  • 1,616 POSTS
It could be caused by a number things the cat being one. I suggest you have the engine scanned to see what is going on. I sincerely hope the timing belt hasn't slipped a tooth. Good luck
Apr 12, 2006 at 5:56 AM
Suggested Repair
Have the engine scanned for trouble codes before replacing parts. Possible causes include a restricted catalytic converter or a timing belt that has slipped a tooth; do not assume the fuel pump is failing without scan results.
Conversation Summary
The owner of a 2000 Toyota Corolla CE with 120,000 miles reports an intermittent check engine light and a one-time refusal to accelerate under hard throttle on a level freeway; the car now runs normally. The expert says several causes are possible, including the catalytic converter, recommends an engine scan, and notes concern that the timing belt may have slipped a tooth.
