Recently the no.1 spark plug blew out of it's hole while driving. I checked compression, it's good and the plug hole threads weren't damaged. Replaced all plugs and dist. Cap and plug wires. The no.1 cylinder does not fire. I have performed the spark check by grounding the plug to the engine and it checks out fine, but when the plug is inserted into the block and the plug wire is removed there is no change in engine performance. I also attached an inductive tachometer to the plug wire. There is no reading when the plug wire is attached to the spark plug but when removed there is a reading. I performed ohms tests on the ignition coil and signal generater and they are both within specs.
SPONSORED LINKS
Sunday, October 28th, 2007 AT 4:25 PM
