Car not telling fans to turn on
HASSAN
  • TOYOTA COROLLA
Hey.
i drive a 1999 toyota corolla, 2 wheel front wheel drive., It runs smooth. But until lastnight it overheated. All in all I found out the fans werent tunrin on any more.
i ran some ground wires from the battery to the fans and the fans work perfectly. Im guessing its maybe the sensors or the computer but I have no idea where to find the temperature sensor for the computer nor the computer, or mayb im jus wrog n those are not the problems if any one has an idea wuts up ill be very much obliged to get a reply.
Friday, September 28th, 2007 AT 7:42 AM
MMPRINCE4000
  • 8,548 POSTS
If you disconnect the fan switch connector the fans should run all the time, if they don't, it could be the fan relay in the fusebox, or the main engine relay.
Monday, October 22nd, 2007 AT 7:22 AM
