car starting problems
PACKYWACKY1B
Hello, I have a 98 toyota corolla. Sometimes my car will start right away, sometimes it takes 4 or more tries :cry: . Once it starts it's fine. When it won't it doesn't even turn over, you just hear a "click". So far I have been able to get it to start but I want to figure out what is wrong. I know it's not the battery as I tested that and it is fine. Could my starter be going out or sticking? What on earth could be the cause of this?????????????????????????????????? I appreciate any help :D Thank you.
Jan 25, 2006 at 9:03 AM
HITEK
  • 30 POSTS
Your starter !
Jan 28, 2006 at 6:23 PM
BOBC
sounds like the starter. when this happened to me it would start only when it was cold or when a friend would tap the starter with a crow bar while i turned the key. happened when I stopped to get gas--when it was hot.
Feb 9, 2006 at 11:17 AM
HITEK
  • 30 POSTS
Replace the contact points only ,not the whole starter.
Feb 11, 2006 at 3:21 PM
