1994 Toyota Corolla Won't Shift Out of Park
TBOAN
I have a 1994 Corolla with 260,000 miles.It starts fine, and runs well. The other day, it just wouldn't shift out of park.I depressed the brake pedal, I squeezed the switch on the shifter, and it just won't shift.I've had it for 12 years, and never had any trouble like this before.I would really appreciate any advice.
Jul 29, 2007 at 2:47 AM
MMPRINCE3000
  • 133 POSTS
It is possible the parking pawl is jammed or the shift cable is out of adjustment/broke or the cable hold down clip is broke or the cable bolt to the transmission is loose.
Aug 11, 2007 at 9:29 PM
Suggested Repair
Check for a jammed parking pawl and inspect the shift cable for misadjustment, breakage, a broken hold-down clip, or a loose cable bolt at the transmission.
Conversation Summary
The owner of a 1994 Toyota Corolla with 260,000 miles says it starts and runs well but will not shift out of park despite pressing the brake and the shifter button. An expert suggests a jammed parking pawl or a shift cable that is out of adjustment, broken, missing its hold-down clip, or loose at the transmission.
