1998 Toyota Corolla Rough Low Gear Shudder
CRONOLLYV
I recently purchase a 1998 Toyota Corolla with 80,000 miles. I changed the air filters, oil filters and spark plugs. Since then I have noticed that it can be a bit rough when taking off in the low gears. The car will shudder violently.
Jan 8, 2007 at 2:53 AM
BACKYARDMECHANIC
  • 337 POSTS
If the problem appeared after you did the work make sure you did not cross the spark plug wires and the are on tight.
Jan 8, 2007 at 5:46 AM
2CARPRO JACK
  • 11,533 POSTS
Also be sure to use OEM parts, Cheaper is exactly that
Jan 8, 2007 at 9:23 AM
Suggested Repair
Confirm the spark plug wires are not crossed and are fully seated and tight. Use OEM-quality parts rather than cheaper substitutes.
Conversation Summary
The owner of a 1998 Toyota Corolla noticed a violent shudder when taking off in low gears after replacing the air filter, oil filter, and spark plugs. Experts advised checking that the spark plug wires were not crossed and are tight, and using OEM parts instead of cheaper substitutes.
