1997 Geo Prizm Runs Rough
WOODENHEAD72
I have a 97 Geo Prizm which most people know has the Toyota Corolla motor and tranny. Anyways, my transmission was going out, so i parked it till i got a replacement. At the time i parked it, it ran fine. After i replaced the transmission, the car now runs rough, there is a definate smell of unburnt fuel in the exaust. I thought maybe it was the Catalytic converter, but after disconnecting the exaust from the manifold, it still runs rough. Im confused about this as i did absolutely nothing motor wise from when it was running fine.
Feb 1, 2007 at 3:15 AM
MMPRINCE3000
  • 133 POSTS
Check all electrical connections you had to undo. The battery ground to the transmission is most important as well as chassis grounds.
Clean all grounds with a wire brush and reinstall.
Feb 2, 2007 at 12:07 AM
Suggested Repair
Check all electrical connections that were disconnected during the transmission replacement. Clean the battery-to-transmission ground and chassis grounds with a wire brush, then reinstall them.
Conversation Summary
A 1997 Geo Prizm ran fine before a transmission replacement but now runs rough with an unburnt-fuel smell. Disconnecting the exhaust did not help. The expert advised checking all undone electrical connections and cleaning the battery-to-transmission and chassis grounds.
