Transmission shifts too much
OSHNEK
Transmission has begun shifting excessively. At certain speeds and accelerator positions it will shift up and down repeatedly. Doesn't seem to be slipping and works great on the highway but can be a pain in town. Any ideas?
'96 Corolla DX
4dr 4 cyl Auto
May 29, 2007 at 6:46 AM
2CARPRO JACK
  • 11,533 POSTS
If the speedo isnt working either, I would suspect the Vehicle Speed Sensor
May 29, 2007 at 10:26 AM
OSHNEK
[quote:a2d2250fcb="2CarPro Jack"]If the speedo isnt working either, I would suspect the Vehicle Speed Sensor[/quote:a2d2250fcb]
Correct, the speedo isn't working. where do I find the vehicle speed sensoe and how do I check it out?
Jun 5, 2007 at 4:17 PM
2CARPRO JACK
  • 11,533 POSTS
Unplug sensor (on top of transaxle) Use a jumper wire and connect battery power to tewrminal 1 on th esensor and ground to term 2.Hook pos lead of meter to term 3 and neg lead to term 2.Spin sensor, output voltage should go from 0-11 volts per 1 revolution of sensor shaft, if not replace it
Jun 6, 2007 at 12:57 AM
