Toyota Corolla Manual Trans Fluid
MKIKIC
corolla, 00/VE, manual
Does anyone knows where I can find photos of corollas manual transmision (change oil SA-90 in transmision) I'm just not sure where to drain transmission oil and where to fil it in.
Thanks,
May 31, 2006 at 2:28 AM
LOSONE
  • 1,616 POSTS
The tranny drain plug is in the bottom and sometimes it is a big allen. The fill and check plug is on the drivers sdie about the middle of the large part of the tranny. Unless is is a mid 70's 4 speed and then it's different. Good Luck
May 31, 2006 at 9:30 AM
Suggested Repair
Drain the manual transmission from the bottom plug, which is sometimes a large Allen fitting. Fill and check the level at the plug on the driver's side, about midway on the main transmission case. A mid-1970s 4-speed may use a different arrangement.
Conversation Summary
The owner of a manual Toyota Corolla asked where to drain and fill the transmission oil (SA-90). The expert said the drain plug is on the bottom and may be a large Allen plug, while the fill and check plug is on the driver's side near the middle of the transmission case, except on some mid-1970s 4-speeds.
