1998 Toyota Corolla Hard Start After Fueling
HOTROD2424
194000k, 98 corolla ce.
I have a new starter and charcoal canister. Car starts fin cold. If its been running a while it may need to turns of the key to start. But the killer is every time i stop to get gas it takes 5-10 minutes to start. And when it does start it idles ridiculously low and shakes a lot, until the rpm's slowly increase. It does this EVERY TIME! The gas cap has be checked and it even runs with no gas cap. The mechanic at my local toyota figured it was the charcoal canister and over $600 later (the next day) its still the same....any info would be appreciated, thanks.
Apr 5, 2007 at 1:37 PM
  • 75,988 POSTS
You probably losing fuel pressure-get a fuel pressure check and then comeback.
When the pump is turned off or stops running, the system should hold residual pressure for several minutes (look up the specs to see how much pressure drop is allowed over a given period of time). If pressure drops quickly, the vehicle may have a leaky fuel line, a leaky fuel pump check valve, a leaky fuel pressure regulator or one or more leaky fuel injectors. Low residual fuel pressure can cause hard starting and vapor lock during hot weather.
Apr 5, 2007 at 3:24 PM
Suggested Repair
Have residual fuel pressure tested after the pump shuts off. If pressure drops quickly, check for a leaky fuel line, fuel pump check valve, fuel pressure regulator, or leaking injectors.
Conversation Summary
The owner of a 1998 Toyota Corolla with 194,000 miles says it starts fine when cold but may need a second key cycle after running. After every fuel stop it takes 5–10 minutes to start, then idles very low and shakes until RPM rises. Checking the gas cap and replacing the charcoal canister did not help. The expert recommends a fuel pressure test, noting that rapid loss of residual pressure from a leaky line, pump check valve, pressure regulator, or injectors can cause hard hot starting.
