2005 Toyota Corolla door window sound
47,000 MILES • 4 CYL • FWD • AUTOMATIC
DESNG
The problem is when closing the passenger side door there is a knock or abnormal sound emitting from the glass window. it sounds like the glass is not secure properly internally but when inspecting the glass physically it seems normal. i don't have power windows.
Any advice would be greatly appreciated.
Dec 18, 2008 at 9:42 AM
MMPRINCE4000
  • 8,548 POSTS
The bolts that hold the window to the regulator may be loose. You will have to remove the interior door panel to inspect them.
Also the regulator could be raising the window crooked.
Dec 18, 2008 at 10:18 PM
