2001 Toyota Corolla
The drivers side power window will lower with no problem. But when I press the switch to raise the window it only moves a short distance (less than an inch) By driving for a while and then pressing the switch it will again ries a little. I can continue to do this until the window has been closed.
I have a small toolkit for home use. Can I be able to open the door and try to fix it. How? Please help.
Thanks in advance.
Thanks in advance.
Jul 22, 2008 at 6:23 AM
