replaced one bulb and now they will not go off?
2003 TOYOTA COROLLA
99,999 MILES • 4 CYL • FWD • AUTOMATIC
HARRY STEPHENSON
Brake lights were out totally. I replaced one bulb and now they will not go off. The bulb I replaced looks good to me.
Aug 10, 2009 at 12:41 PM
  • 31,937 POSTS
Hi there,
You will need to check for a faulty brake light switch, this is located at the top of the brake pedal, you will need to check for power in and out of the switch when depressed, no power should pass through the switch with it up.
Mark (mhpautos)
Aug 10, 2009 at 1:14 PM
