when I start car, the battery light and brake light stays on. emergency brake released light still stays on. no problem starting car.
Nov 16, 2009 at 12:49 PM
✓Experienced Mechanic
Batery light coming on-could mean the alternator is not putting out get it load tested.
Nov 16, 2009 at 1:09 PM
Hi there,
Have the alternator charge rate check to ensure that the charge rate is ok, also have the brake fluid level checked as it may be low causing the dash brake indicator light to show up, start here.
Mark (mhpautos)
Nov 16, 2009 at 1:11 PM
MMPRINCE4000
Take to any autoparts store and get alt. tested.
The BATT and BRAKE light come on to indicate an insuffcient charge, (under 12V).
