1995 Toyota Corolla brake lights
ASKME53
1995 Toyota Corolla 4 cyl
my brake lights wont turn off and half of a small round black plastic thing was found on the floor by the brakes
Sep 11, 2009 at 11:21 AM
  • 75,988 POSTS
Sounds like the brake switch is a goner-follow the brake pedal arm till it meets up with the support bracket you'll find it right here.
Sep 11, 2009 at 11:36 AM
MMPRINCE4000
  • 8,548 POSTS
The black plastic thing is a spacer that fits on the brake pedal. If missing, the brake switch would be out of adjustment.
You can try adjusting the brake switch, to compensate for the loss of the spacer.
Sep 12, 2009 at 1:13 AM
