2001 Toyota Corolla Slippage
JEN9192
  • 2001 TOYOTA COROLLA
  • 4 CYL
  • FWD
  • MANUAL
  • 13,800 MILES
When I shift into 2nd or 3rd, the engine sounds like I'm in neutral until it grabs hold and allows me to accelerate.
What could the problem be?
Wednesday, April 9th, 2008 AT 1:44 PM
MMPRINCE4000
  • 8,548 POSTS
I would say that if the clutch pedal is firm and engages from a stop, but you have slippage when accelerating and shifting into 2-3, it may be a bad motor mount causing a bind.
You also should check the slave cylinder (fluid level) and the clutch fork for binding.
You could also have a bad clutch, bent fingers, bent clutch fork etc.
Wednesday, April 9th, 2008 AT 6:07 PM
