1999 Toyota Corolla oil leaks
JAYPOY_22
  • 1999 TOYOTA COROLLA
  • 4 CYL
  • MANUAL
  • 176,000 MILES
1999 Toyota corolla sedan. The engine oil leaks. The servitech technician said that the trouble is at the oil seal of the engine. What should we do?
Monday, January 12th, 2009 AT 6:13 AM
BMRFIXIT
  • 19,053 POSTS
You have a lot of oil seals in the engine
witch one is it
is it in the front by the oil pump
and if so I would suggest replacing oil pump seals and O ring plus timing belt
Monday, January 12th, 2009 AT 6:20 AM
