1999 Toyota Corolla oil leak
FARRELL02
  • 1999 TOYOTA COROLLA
  • 4 CYL
  • 103,000 MILES
Oil leaking from the oil pressure switch. How do you change the oil pressure switch
Sunday, May 25th, 2008 AT 9:23 PM
  • 31,937 POSTS
Hi there,
Just undo the wire, and the switch will unscrew using a suitable socket or spanner. Do not use any sealant on the thread as it is tapered & self sealing, you need a good earth at the thread for it to work.
Mark (mhpautos)
Sunday, May 25th, 2008 AT 10:14 PM
