The oil cap (if loose, or not sealing) will cause a lot of oil to leak.
Other possibility is that oil pump relief valve is stuck causing excessive oil pressure.
Measure oil pressure with mechanical gauge to see if pump is problem.
SPONSORED LINKS
Sunday, October 10th, 2010 AT 8:39 AM
