1999 Toyota Corolla MOTOR SWAP
GREENTHUMB1
  • 1999 TOYOTA COROLLA
Engine Performance problem
1999 Toyota Corolla 4 cyl Front Wheel Drive Automatic
WELL I JUST WOULD LIKE TO KNO IF ITS POSSIABLE TO PUT A K24 MOTOR INTO A 1999 COROLLA
Friday, September 11th, 2009 AT 3:40 AM
MMPRINCE4000
  • 8,548 POSTS
There is no "K24" Toyota designation that I am aware of.
1ZZFE, 1ZZGE, 4AFE, 4AGE are Toyota designations. What exactly is a K24?
Friday, September 11th, 2009 AT 6:32 AM
GREENTHUMB1
ITS A HONDA K24 ENGINE. WHICH WOULD ALSO BE USED BY ACURA IN THE NEW ACURA RSX
Friday, September 11th, 2009 AT 10:40 AM
MMPRINCE4000
  • 8,548 POSTS
Anything is possible, but you would have to change engine, trans, entire wiring harness, PCM, motor mounts etc.
You would probably have to weld new mounts to the cradle, you may also have to have custom CV axles made, and use the Honda front brake system.
LARGE job, you may be better off looking for a turbo, supercharger kit for the Toyota engine.
Saturday, September 12th, 2009 AT 7:59 AM
