1989 Toyota Corolla 1989 Corolla Ignition System Advance(Ca
TRINI3232
  • 1989 TOYOTA COROLLA
Engine Performance problem
1989 Toyota Corolla 4 cyl Front Wheel Drive Automatic
How does this sytem work to advance the spark?
Thanks
Monday, January 26th, 2009 AT 9:13 AM
MMPRINCE4000
  • 8,548 POSTS
There ar two advance settings on a car with a dist. Mechanical advance and computer advance.
Mechanical advance is set with timing light. Computer advance is controlled by ECM.
https://www.2carpros.com/how_does_it_work/ignition.htm
Monday, January 26th, 2009 AT 9:23 AM
TRINI3232
The wiring schematics for the Carb version, mentions a Throttle Switch. Is this a Throttle Position Sensor? I replaced the Fuel Pump and Filter, and my car still spits and backfires when I go to accelerate. If I shift the car manually(3 sp auto), I can get the car to drive normal. Is it the accelerator pump in the carb, or the ign advance?
Monday, January 26th, 2009 AT 9:32 AM
MMPRINCE4000
  • 8,548 POSTS
Something with fuel delivery.
If ignition related, it would do it all the time.
Tuesday, January 27th, 2009 AT 11:03 AM
