1989 Toyota Corolla Allining
CURTIS67
  • 1989 TOYOTA COROLLA
Tires and Wheels problem
1989 Toyota Corolla 4 cyl Two Wheel Drive Automatic
From where do I adjust the allinment for the back at wheels.
Wednesday, October 28th, 2009 AT 12:11 PM
MMPRINCE4000
  • 8,548 POSTS
Raise rear of car, put on stands. Grasp tire and push/pull both horizontally and vertically, if any movement then possible control arm bushings, bent control arm, wheel bearing.
Alignment can be adjusted with shims, but most likely you have a bad bushing, bent control arm or worn wheel bearing.
Thursday, October 29th, 2009 AT 10:58 AM
