1997 Toyota Corolla
TARUS5GY
  • 1997 TOYOTA COROLLA
1997 Toyota Corolla
what causes continious white smoke to come from the exhaust system
Saturday, September 20th, 2008 AT 8:03 AM
MMPRINCE4000
  • 8,548 POSTS
A leaking head gasket or a cracked head. This usually occurs when the car overheats.
This needs to be repaired ASAP, because if it is actively leaking in the cylinder, you take a chance that you will "hydraulic" the engine. Which means that coolant leaking in the cylinder will accumulate to the point where the piston will try to compress it (liquids are not compressable) and you will bend a rod or break the crank.
Sunday, September 21st, 2008 AT 7:11 AM
