How to remove power steering belt?
DEEPBLUESEA1226
  • 7 POSTS
Thank you guys. I finally got the belt out.
Saturday, February 17th, 2018 AT 1:38 PM (Merged)
MMPRINCE4000
  • 8,548 POSTS
Great news.
Make sure to inspect pulleys and clean with brake clean. Brake clean dissolves grease, grime, coolant and leaves no residue.
SKEEZIK
  • 1994 TOYOTA COROLLA
  • 4 CYL
  • FWD
  • 11,200 MILES
Steering problem
1994 Toyota Corolla 4 cyl Front Wheel Drive Automatic 112, 00 miles
How do you replace the Power Steering Belt on a 1994 Toyota Corolla? I see one bolt that holds the power steering pump to a bracket and I loosened it but the pump didnt move. HELP.
MMPRINCE4000
  • 8,548 POSTS
The bolt allows the pump to pivot, but you must loosen the base bolt ( the bolt that holds the pump at the bottom) to allow it to pivot, then replace belt, adjust tension, tighten pivot bolt, then base bolt.
OMGVTEC90
Im having a similar problem I got my pulley loose but it wont move so I cant get my new belt on. What should I try
GULF81STAR
  • 1998 TOYOTA COROLLA
  • 4 CYL
  • FWD
  • 135,000 MILES
Engine Mechanical problem
1998 Toyota Corolla 4 cyl Front Wheel Drive Automatic 135000 miles
How do you go about replacing the serpentine belt on a Corolla?L
KHLOW2008
  • 41,814 POSTS
Hi gulf81star,
The Auto tensioner has a 19 mm hex head which you can use to release the tension to remove the belt.
https://www.2carpros.com/forum/automotive_pictures/192750_SerpentineToyota98_1.jpg
