1995 Toyota Corolla My car starts but wont Move forward. On
SDECKARD
  • 1995 TOYOTA COROLLA
Transmission problem
1995 Toyota Corolla 4 cyl Front Wheel Drive Automatic
My car will only move in reverse. The engine runs good but when I push on the gas to move forward, it doesn't budge. Only backwards is my car motive. What is wrong with my car?
Thursday, August 28th, 2008 AT 11:51 AM
MMPRINCE4000
  • 8,548 POSTS
Check the fluid level in the transmission first, make sure it is full.
Also check the differential fluid, if out of fluid, the differential may have begun to sieze, and most likely you will need to have the trans. Replaced
Friday, August 29th, 2008 AT 6:18 AM
