By Holding the gas paddle all the way down to the floor
you are activating flood mode
meaning you are stopping the injectors from delivering the fuel to the cylinder
so you have to much fuel in the cylinder and not burning
so you need to check :
1. Spark plugs and wires (tune up)
2. Check coil and if you have strong enough spark arcing
3. Check also sensors and EGR
4. Check idle air control valve and clean
5. Check timing
Saturday, April 26th, 2008 AT 5:44 PM
