You will have to remove the inside door panel and inspect window regulator. If I remember correctly, Toyota windows are bolted in (as opposed to rivets), so a bolt may have come loose.
If regulator is bad, go to junk yard and get used regulator from same year Corolla or Geo Prizm.
Also remove window tracks from donor.
If you find a 95 Corolla at the junk yard (U Pull It), remove any good interior parts, distributor, fuse/relay junction boxes, sensors (MAP, TPS), whatever you can afford.
The ign. Module alone in the distributor costs over $300, so it would be a good time to "stock up" on parts if you intend to keep car.
SPONSORED LINKS
Thursday, May 21st, 2009 AT 6:27 AM
