1994 Toyota Corolla Passenger front power window
1994 TOYOTA COROLLA
323,155 MILES • 4 CYL • 2WD • MANUAL
CRUSINGG
The front passenger power window goes down ok but does not come up . THe motor is running but the window does not move. Car is a 1994 Toyota Corolla
Sep 3, 2008 at 12:16 PM
MMPRINCE4000
  • 8,548 POSTS
You will have to remove the inner door panel and further inspect the window.
The regulator could be rusted or binding, or the motor gear could be broke, slipping. I would also replace the window switch while you're at it.
You could probably get the parts you need at a junk yard, since they would probably be expensive at Toyota.
Sep 3, 2008 at 11:14 PM
