1991 Toyota Corolla break equalizer
MARYSTRIDIRON
Brakes problem
1991 Toyota Corolla 4 cyl Front Wheel Drive Automatic
when brakes get hot they get very thight and then lock. car repair person said i need a break equalizer.
Nov 15, 2008 at 9:33 AM
ZACKMAN
  • 4,202 POSTS
You don't have a brake equalizer, but you have a proportioning valve.
https://images.2carpros.com/forum/automotive_pictures/55316_Proportining_Valve_1.jpg
First, install pressure gauges to P Valve. Bleed the brake system. Raise master cylinder pressure for front wheel and increase rear wheel pressure gauges. Rear pressure increase should be less than front pressure. If pressure is not at specified level, replace the valve.
Nov 15, 2008 at 4:13 PM
