1991 Toyota Corolla
HAYES1324
  • 1991 TOYOTA COROLLA
Engine Mechanical problem
1991 Toyota Corolla 4 cyl Front Wheel Drive Automatic
I have a 91 Toyota corolla that dies when you come to a stop but it will stay running if put in to neutral. Do you have any idea what may be wrong?
Sunday, January 31st, 2010 AT 8:36 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Does it idle OK in Park as well as Neutral? If so then suspect faulty torque converter clutch (TCC) lock up solenoid.
Sunday, January 31st, 2010 AT 8:46 PM
HAYES1324
I will try that and see if it works. Thank You for your time.
Monday, February 1st, 2010 AT 7:22 PM
MMPRINCE4000
  • 8,548 POSTS
Also check differential fluid level, access is through a bolt on rear of differential.
This is a highly neglected maint. Item on early Toyota's.
Tuesday, February 2nd, 2010 AT 8:17 AM
