where is the horn located on a 1991 toyota cornolla
Tuesday, April 8th, 2008 AT 5:28 PM
MECHANIC
I should be behind the grille on the right hand side.
Have a look there,
mark (mhpautos)
SPONSORED LINKS
Wednesday, April 9th, 2008 AT 5:06 AM
MMPRINCE4000
MECHANIC
If your horn is not working, check the ground (the bolt that holds the horn on). They will get corrosion in there and stop working.
If you depress the horn button and hear a "click" then the ground is bad.
