2003 Toyota Corolla HORN INOP
2003 TOYOTA COROLLA
JRT
  • 27 POSTS
Electrical problem
2003 Toyota Corolla 59655 miles
RELAY AND FUSE HAVE BEEN SUBSTITUTED AND THEY WERE GOOD. HORN WIRE IS ON.
REPLACE HORN OR PULL STEERING WHEEL?
Jan 22, 2008 at 7:52 AM
MMPRINCE4000
  • 8,548 POSTS
When you depress the horn button on the steering wheel you should hear the relay click. If so then the horn is bad or it has a bad ground.
If you remove the horn and connect directly to 12V and it works, then the horn is not grounded properly.
It grounds to the chassis.
Jan 22, 2008 at 10:57 PM
JRT
  • 27 POSTS
THANKS FOR INFO. I WON'T SEE VEHICLE FOR A COUPLE MORE DAYS, BUT I'LL LET KNOW THEN.
Jan 24, 2008 at 12:35 AM
JRT
  • 27 POSTS
PULLED POWER WIRE AT HORN TO VERIFY 12V WAS PRESENT AND IT WAS. PLUGGED WIRE BACK IN AND NOW THE HORN WORKS! GUESS IT WASN'T QUIT TIGHT ENOUGH OR CONNECTION WAS DIRTY.
ALL IS WELL...........
THANKS
Jan 26, 2008 at 9:18 AM
