Hello my? Is that my brake lights are staying on when the lights are on and no one is pressing the brake. What can I do.
Friday, June 13th, 2008 AT 10:26 PM
MECHANIC
Hi there,
You will have faulty brake light switch which is mounted on the top of the brake pedal under the dash.
Mark (mhpautos)
SPONSORED LINKS
Wednesday, March 17th, 2021 AT 6:12 PM
MMPRINCE4000
MECHANIC
There is also a small plastic "pad" that the brake switch touches that can break and fall off causing the switch to not contact the pedal. You can adjust the switch, but if it will not shut off then as Mark said the switch is bad.
