1990 Toyota Corolla Intake
JACKOLSON
  • 1990 TOYOTA COROLLA
  • 4 CYL
  • FWD
  • MANUAL
  • 85,000 MILES
I have a carbey.
What do you mean by "running the intake thru the A/C or to the A/C"?
And, how do I properly set the A/F ratio? Using the old school "tune by sound" and using the gas analyzer. Why should I set it to Lean Best Idle? What's Lean Best Torque? What are the downsides of running it rich? I realized that a rich mixture, say a rich best torque helps cold burning, mean the cylinders don't get that hot. I know it may foul up the spark plugs but I'd rather replace plugs than cylinders. Right?
The internet documents are just crap, they always talk about a certain ratio for their products and they always talk about EFI, I don't have EFI, and I don't want EFI. I like to stick with the old school carburetor.
Thanks.
Friday, November 20th, 2009 AT 2:30 AM
MMPRINCE4000
  • 8,548 POSTS
Best way to set the A/F ratio is on a chassis dyno with a wideband O2 sensor.
Cruising generally runs an AF ratio of 14.7 to 1. When at WOT or power is needed, AF drops to 13.0 to 1 or sometimes lower. This is to prevent a lean engine which can burn a piston is seconds.
It has been several years since I used a chassis dyno to tune a car (nitrous), but it was $75 for the session.
Friday, November 20th, 2009 AT 8:26 AM
JACKOLSON
  • 67 POSTS
It would take eternity to find a dyno here in my country, LOL, people are just so old school here that I don't even see anyone using that much tools, modern tools on their vehicles, but anyway, since I don't have access to a dyno, can I have my car checked for emissions and just take note of the O2 reading? Is that right? The O2 reading will give me an idea of my A/F ratio, right? What value am I after so that I will have a stoich A/F ratio of 14.7:1? I can set it up higher than that right, a little bit rich, just to induce a little cold burn, right? I am not considering fuel economy. I'd pay for fuel than pay for repairs. Am I making sense of what I'm doing?
Thanks and more power.
Friday, November 20th, 2009 AT 10:45 PM
MMPRINCE4000
  • 8,548 POSTS
Wideband O2 sensors are much more sensitive to A/F ratio than standard ones.
They have come down it cost considerably from 10 years ago when they cost $2000.
The problem with a standard O2 sensor is that it is not "real time". Widebands are real time.
Start rich and work your way back, under WOT NEVER get above 13:1.
Saturday, November 21st, 2009 AT 8:53 AM
