1990 Toyota Corolla car turns off
MOEBLEY12
  • 1990 TOYOTA COROLLA
1990 Toyota Corolla 196665 miles
i got a toyota corolla 4 door dx, manual and it turns on fine. However, when I try to move it and put in the 1st gear and accelerate while removing the clutch, it turns off. I recently changed the spark plugs thinking that was the problem and when I checked them, 2 of the spark plugs were oilly and had motor oil on them. I had to clean them up along with the spark plug slot. It still had the same problem. Why does this happen?
Sunday, May 24th, 2009 AT 5:45 PM
  • 109,867 POSTS
Does the engine run smoothly when it idles? Also, when you say there was oil on the plugs, was it on the electrode (the part that goes in the engine) or the outside of the engine?
Sunday, May 24th, 2009 AT 7:03 PM
MMPRINCE4000
  • 8,548 POSTS
Also check the clutch start safety switch, this prevents the engine from being started unless clutch is depressed. It may be malfunctioning/shorting causing the engine to shut off.
Monday, May 25th, 2009 AT 8:27 AM
