Engine wont run?
KHLOW2008
  • 41,814 POSTS
You need to find out if it is ignition sparks or fuel that is missing. Our DIY section has information on how to go about performing tests.
Do you have engine overheating or coolant losses issues?
Is the MIL indicating?
Monday, August 10th, 2020 AT 11:51 AM (Merged)
RTLAWSON
  • 1990 TOYOTA COROLLA
  • 225,444 MILES
1990 Toyota Corolla won't start.
Replaced Plugs, Plug Wires, Distributor Cap, Rotor, Ignition Coil, Fuel Pump, EFI Fuse(blown)
Before replacing fuel pump, the Check Engine light would come on when starting car, but go out as soon as EFI Fuse blew.
After replacing fuel pump, Check Engine light not coming on. EFI fuse good.
After replacing fuel pump, using starter fluid, the car started and ran for about 2 mins. It shut off and I have not been able to restart.
I have pressure at the fuel rail. I don't have any way to test the pressure, but it sprays out when I loosen the connection on the end of it.
Also note that this vehicle was sitting for about 18 months. I pumped out as much old gas as I could and replaced with fresh gas.
Any thoughts, hopes or prays?
Monday, August 10th, 2020 AT 11:52 AM (Merged)
It sounds like the ignition coil is shorted, have you checked it?
RTLAWSON
Nice work, the coil was red hot when I checked it, I replace it and now the car works great, thanks 2carpros. Com
Thanks!
KF4PSB
  • 1.6L
  • 4 CYL
  • 100,000 MILES
My car will spin but will not start. It would hit but now it will not do that. Could it be my fuel pump? If you think so how do I check it?
Monday, August 10th, 2020 AT 6:24 PM (Merged)
KHLOW2008
  • 41,814 POSTS
When engine cranks and does not start up, you need to find out what is missing first.
Check out the above link to find out what is missing and proceed from there. Link below provides more information on almost all system checks.
https://www.2carpros.com/articles
GODSGIRLCATHY
  • 4 CYL
  • 189,000 MILES
My car wont turn over when I start it it just reves, my friend said the gas is not passing through, how can I tell if it just needs a fuel filter or a whole new pump? How can I test it to see if its the fuel pump?
MMPRINCE4000
  • 8,548 POSTS
If this carb or FI?
