1990 Toyota Corolla where do I go to change the engine on m
XIOMY23
  • 1990 TOYOTA COROLLA
  • 4 CYL
  • 150,000 MILES
I want to change the engine on my car but I dont know where to go. Antifreeze is passing over to the spark plugs and the head gasket needs to be changed so might as well change the engine.
Sunday, February 24th, 2008 AT 6:23 PM
BLACKOP555
  • 10,371 POSTS
Head gasket will only cost around 1000 dollars to change, to find out where to go to change an engine your best bet would be call a junk yard and ask them for a running engine that will fit your vehicle and then contact a mechanic near you and ask them if they can put it in for you.
Sunday, February 24th, 2008 AT 7:01 PM
