1990 Toyota Corolla Engine support
120,000 MILES • 4 CYL • FWD • AUTOMATIC
NONGBOCK
How do you replace the rear engine support of the 1.6 EFI engine of the Toyota Corolla sedan?
Aug 11, 2009 at 4:52 PM
  • 31,937 POSTS
Hi there.
This is best done on a hoist as the splash trays and lower cross member must be removed, remove the engine pipe for better access and the mount through bolt can be un done and the mount removed, it is advised to use an engine bay engine support beam as the engine will start to over stress the two remaning mounts.
Mark (mhpautos)
Aug 11, 2009 at 5:14 PM
