1990 Toyota Corolla Clutch Slipping
RHWILSON
Just given this car. Had it checked out. New cylinder for clutch. Everything was checked off. Clutch pedal is very high. Manual Trans. Slips very bad. can I adjust the clutch at home or take it back to mechanic
Nov 15, 2007 at 6:15 AM
  • 75,988 POSTS
The fact that the clutch pedal is so high means the clutch is worn out, but to be sure please go over his video.
https://youtu.be/EpBMj5ZY_bo?si=nAXr6aMujvGkGyvk
Let us know if you need anything else.
Nov 15, 2007 at 6:42 AM
Suggested Repair
A very high clutch pedal with severe slip indicates a worn clutch rather than a simple adjustment. Review the diagnostic video to confirm, then have the clutch replaced if wear is verified.
Conversation Summary
The owner of a 1990 Toyota Corolla with a manual transmission reports severe clutch slip and a very high clutch pedal after a new clutch cylinder was installed. The expert says the high pedal indicates the clutch is worn out and recommends reviewing a diagnostic video to confirm.
