1989 Toyota Corolla Cold Misfire Smoke
THEOG23
89 Corolla Csx 138,000kms 1.6 DOHC 4A-FC
When the engine is cold the 1st cylinder doesnt fire and alot of blue smoke comes out the exaust. When hot the car runs good and no smoke comes out.
Can anyone help me with why this is happening , Thanks
Sep 20, 2007 at 3:04 PM
  • 75,988 POSTS
[quote:4a8fe2cc6b="theog23"]89 Corolla Csx 138,000kms 1.6 DOHC 4A-FC
Can anyone help me with why this is happening , Thanks[/quote:4a8fe2cc6b]
Your valves seals needs replacing and no.1 don't could be a compression problem/bad plug/ and wire to include the no.1 terminal on the distributor cap
Sep 20, 2007 at 7:58 PM
Suggested Repair
Replace the valve seals. Also check cylinder 1 compression, the spark plug and plug wire, and the number 1 terminal on the distributor cap.
Conversation Summary
A 1989 Toyota Corolla with the 1.6 DOHC 4A-FC engine misses on cylinder 1 and emits a lot of blue exhaust smoke when cold, then runs well with no smoke once hot. The expert said the valve seals need replacement and that the cylinder 1 miss could also be a compression problem, a bad plug or wire, or a fault at the number 1 distributor-cap terminal.
