THE PROBLEM -
Car is using oil fairly rapidly and burning black smoke. (Don't know exact amount but probably a quart every few hundred miles or so.) There are no visible leaks. There doesn't appeart to be much if any smoke in the exhaust when idling or when cruising but revving the engine up to 5k rpm or so produces substantial black smoke. (This could have been happening even before the VVT gear swap, but I have no way of knowing).
The car runs smoothly and light acceleration is not a problem. It does seem to miss a bit during moderate-hard acceleration, but it isn't terribly noticeable, and I just chalked it up to the small engine size and mileage.
Is there any reason that the VVT gear replacement could be the instigator of this problem? If not, what would be the most likely cause(s).
SPONSORED LINKS
Tuesday, August 7th, 2007 AT 3:14 PM
