HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Corolla
Engine
Symptoms
Not Running
SPONSORED LINKS
1987 Toyota Corolla when cold
DAWID
MEMBER
1987 TOYOTA COROLLA
Engine Performance problem
1987 Toyota Corolla Front Wheel Drive Manual 500000 miles
why do my car not run even when started in winter mornings it idea is not even until the engine is hot what could be the problem
Wednesday, June 9th, 2010 AT 3:02 AM
MECHANIC
Clean out the idle air control valve and see what happens
SPONSORED LINKS
Wednesday, June 9th, 2010 AT 4:27 AM
DAWID
MEMBER
How do it look
Wednesday, June 9th, 2010 AT 4:36 AM
MECHANIC
Go to:
http://www.youtube.com/watch?v=i82s4ZfR2js
Wednesday, June 9th, 2010 AT 5:51 AM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
1987 Toyota Corolla Fx Won't Start
The Car Will Start When Cold, And Run Fine Once It Starts. But Once It Gets Hot, If You Stop For 30 Mins - 1 Hr Or So, Then Try To Start...
Asked by
jchamberlain
1987
TOYOTA COROLLA
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
1987 Toyota Corolla Carburator
Engine Mechanical Problem 1987 Toyota Corolla 4 Cyl Front Wheel Drive Manual 152k Miles The Car Has Been In A Garage For 9 Years. ...
Asked by
dnadna11
1987
TOYOTA COROLLA
Engine Not Running?
I Am Getting Codes Po100 And Po110. My Question Is: With This 2 Codes Will It Prevent The Car From Starting Completely? After Continuous...
Asked by
silvano100862
1 ANSWER
2002
TOYOTA COROLLA
The Engine Cranks But It Wont Start
Hi, I Drive A Corolla 1.6 - 1993, 4afe Engine With Approx 200k Kms On The Meter. It Was Running Absolutely Fine! I Drove It Over...
Asked by
lecancy
7 IMAGES
1993
TOYOTA COROLLA
Car Will Not Start
Electrical Problem 4 Cyl Front Wheel Drive Manual 200000 Miles Hello, I'm Working On A 1990 Toyota Corolla As A Favor For A Friend...
Asked by
cdshaa
1990
TOYOTA COROLLA
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Replacement
Crankshaft Sensor Symptoms
Online car repair manuals
