1987 Toyota Corolla Carburator
DNADNA11
  • 1987 TOYOTA COROLLA
Engine Mechanical problem
1987 Toyota Corolla 4 cyl Front Wheel Drive Manual 152k miles
The car has been in a garage for 9 years.
Car will not start.
Have replaced fuel filter, fuel pump.
Have cleaned both jets in carb and cleaned bowl of all old gas.
gas flows from pump to carburator but does not reach the piston chamber.
Where do I look for stoppage?
Tks.
Friday, August 14th, 2009 AT 12:55 PM
DOCFIXIT
  • 18,828 POSTS
Spray some carb cleaner into carb. See if it fires. If no then check for spark if yes then think a rebuild is in order. The old gas drying up in small passageways gunks up and needs to be soaked to clean out.
Friday, August 14th, 2009 AT 1:10 PM
DNADNA11
Thanks so much for your rapid response.
Have sprayed heavily with cleaner. Guess rebuilding is in order.
Thanks again.
Friday, August 14th, 2009 AT 1:22 PM
