HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Corolla
Engine
Timing Belt
Timing belt timing
DEWINNA
MEMBER
1986 TOYOTA COROLLA
4 CYL
FWD
AUTOMATIC
140,000 MILES
How to put auto back in correct timing. Thanks
Tuesday, February 16th, 2010 AT 10:54 AM
MMPRINCE4000
MECHANIC
Here is a guide to help with sidearms below
https://www.2carpros.com/diagrams/toyota/corolla/1986
Tuesday, February 16th, 2010 AT 3:48 PM
Please
login
or
register
to post a reply.
Related Timing Belt Content
1995 Toyota Corolla Timing Belt
Is The Toyota 1.6l L4 Fi Engine An Interference Engine That Will Suffer Engine Damage If The Timing Belt "breaks'. I Was Told That...
Asked by
coward3
1995
TOYOTA COROLLA
GUIDE
Timing Belt
Automotive combustion engines require either a timing chain or belt to keep the camshaft to crankshaft correlation correct as part of the design of the engine. A timing belt...
I Check Out A Link For Trouble Shooting, Now I Have A...
When I Totally Took Out The Timing Cover & Check The Top Crank Wheel Above It Didn't Move Nor Rotate When I Crank It To See Movement? What...
Asked by
MichaelLSJ
2 IMAGES
1991
TOYOTA COROLLA
Timing Belt
I Need The Diagram, Picture, Of A 1994 Toyota Corolla 1.8 To Show Me How To Put The Timinig Belt Back On. That Way It Will Be Put On Right...
Asked by
RLove34
1 IMAGE
1994
TOYOTA COROLLA
1989 Toyota Corolla Timeing Belt
One Morning I Woke Up To Warm Up The Car But When I Tried To Start The Car The Timeing Belt Just Snapped I Would Like To Know If I Would Be...
Asked by
MANIAC
1 ANSWER
1989
TOYOTA COROLLA
If The Timing Belts Are Not Done Right, What Will...
Was Told That Car Is Idleing To Low And Timing Is Out. What Happens When Timing Is Out?
Asked by
Angieee
1993
TOYOTA COROLLA
VIEW MORE
Engine Not Starting
Serpentine Belt Replacement Chevy 1500
Serpentine Belt Replacement Ford Explorer
