I Check Out A Link For Other Trouble Shooting, Now I Have A Timing Belt Pulley Problem?
MICHAELLSJ
  • 1991 TOYOTA COROLLA
  • 111,001 MILES
When I totally took out the timing cover & check the top crank wheel above it didn't move nor rotate when I crank it to see movement? What do I do now? Do I open also to check the lower level of the belt below to see it the timing belt is warp out? & May I kindly know how to do the (TDC) for My Vehicle? Thank you.
Friday, July 12th, 2013 AT 4:35 AM
PONTEEAK
Hi my name is jermaine its possible that your timing belt has shed some teeth and is no longer turning the camshafts. Avoid cranking the engine this could put the pistons in contact with the valves and you will need to pull the cylinder head and get the valves replaced. You should check for pieces of rubber in the lower part of the timing cover to verify damage to the timing belt, If it's damaged youshould replace the timing belt and get a timing belt componet kit it has all the replacement pulleys tensioners and springs you will need to insure a trouble free install. Pics below are from autozone. Com
Friday, July 12th, 2013 AT 6:29 AM
HMAC300
  • 48,601 POSTS
If it doesnt' say expert by thename it's not from 2carpros. To get tdc, bring #1 cylinder up and timing mark on crank pulley to mark. The other info on the reply seems correct.
Friday, July 12th, 2013 AT 6:57 AM
MICHAELLSJ
  • 27 POSTS
To: hmac300 (expert),
thank you,
also what about When I totally took out the timing cover & check the top crank wheel above it didn't move nor rotate when I crank it to see movement? What do I do now? Do I open also to check the lower level of the belt below to see it the timing belt is warp out?
Friday, July 12th, 2013 AT 7:36 PM
HMAC300
  • 48,601 POSTS
Yes it is probably that or broken
Saturday, July 13th, 2013 AT 5:51 AM
