1985 Corolla Ball Joints
LDONAYRE
I have a 1985 Toyota corolla SR-5, 1.8L engine with 120k miles.
My question is: Can I replace only the ball joints and not the whole control arm/ball joint assembly or is this some kind of one piece unit?
The ball joints need to be replaced. The dealership and manuals state that the control arm and ball joint must be replaced together but, no explanation beyond that.
I have been able to purchase the ball joints ($60 for the pair) but, before I start I don't want to get it all torn down only to find out that I do need the $1500 control arms.
I can't tell from looking at them on my car and I can't seem to find any explaination on whether it is possible to only replace the ball joints independent of the control arms.
Thanks,
-Lou
Sep 30, 2007 at 1:51 PM
  • 31,937 POSTS
Hi there,
These ball joints are very simple to to, wheel off, un do ball joint nut & break tapered joint, you may need a few sharp blows from a heavy hammer. Un do two bolts / nuts on lower control arm and lift out ball joint. Always use jack stands and safty goggles, support the control arm while breaking taper so things don't get out of control.
Mark (mhpautos)
Sep 30, 2007 at 4:12 PM
