2000 Toyota Celica Engine Ticking
D-DIZZLE
Hi, I have a 2000 Toyota celica GT with 85k miles. Car runs like a champ, but my engine has ticking noise at idle speeds. Idle itself seems rough, I can feel vibration inside. It had check engine light on, which showed 1st cyl. misfire, changed spark plugs and the light went off. Ticking is not persistent, it comes on and goes off. It can be 1 tick sound or few ticks in a row. When I listen to the engine it seems like the ticking comes from the left side of it. When I accelerate engine it cant be heard any more. Car doesn't burn oil, engine has power. I showed it to several mechanics including toyota service center, they say there is nothing to be worried about. Any suggestions?
Oct 1, 2007 at 9:17 PM
  • 75,988 POSTS
Do an engine flush change oil and filter every 2500 miles you keep this maintenance up and the other stuffs as required-you'll go another 7yrs.
Oct 1, 2007 at 10:14 PM
  • 75,988 POSTS
Inbox :: Message
To: rasmataz
Posted: Tue Oct 02, 2007 7:31 pm
Subject: engine ticking.
Thanks a lot, I also heard about various oil additives, sea foam. Is that any good to use? Also I have never done engine flush before. I just bot this car 2 months ago. How can I get engine flush done?
I really like this car and want to stick with it, invest some money into tune up like intake, exhaust, pulleys just for more efficient run. I am not a racer, I rarely pass 3500rpm. Actually someone told me that ticking noises in toyotas occur often and reason being poor maintenance.
What type oil would be the best? I guess synthetic is the only way to go.
And thank you for your time again, I really appreciate your dedication to this web and its customers.
_________________
Dariushas
Have you done the things I've told you to do.
Oct 3, 2007 at 3:26 AM
Suggested Repair
Perform an engine flush, then change the oil and filter and continue oil and filter changes about every 2,500 miles along with other required maintenance.
Conversation Summary
The owner of a 2000 Toyota Celica GT with 85,000 miles reported intermittent ticking at idle from the left side of the engine, plus idle vibration. A cylinder 1 misfire code cleared after the spark plugs were replaced. The car does not burn oil and still has power, and several mechanics including a Toyota service center said it was not a concern. The expert advised an engine flush and oil and filter changes every 2,500 miles with ongoing maintenance, and asked whether that advice had been followed.
