2000 Toyota Celica Belt Squeal
AHMEDZ
I have the 2000 Toyota Celica GTS with 24500 miles on it. I just bought it a few months ago. It seems to squeal when started and seems to do less so after use.
The car mechanic suggested I get "belt dressing" and put on it. The NAPA parts dealer told me that belt dressing works with older cars but would be destructive on my car (he gave some convoluted reason).
Should I change something? What belts? Is this expensive?
Thanks.
Sep 25, 2007 at 7:29 AM
FISHERMAN
  • 937 POSTS
The belt dressing makes a mess on your pulleys..
better replace the belts...
and check for proper tension on them.
Sep 25, 2007 at 9:43 AM
BUZZSAW
  • 1,198 POSTS
[quote:2c3d112f18="fisherman"]The belt dressing makes a mess on your pulleys..
and check for proper tension on them.[/quote:2c3d112f18]
if outside belts need replacing so does the T-Belt, try a crayon to quiet belts,
t-belt replacement= 4 yrs or 60k miles
Sep 26, 2007 at 12:44 PM
Suggested Repair
Replace the accessory belts and check that they are properly tensioned. Do not use belt dressing, which can contaminate the pulleys. If the outer belts are replaced, also consider the timing-belt interval of 4 years or 60,000 miles.
Conversation Summary
The owner of a 2000 Toyota Celica GTS with 24,500 miles reports belt squealing at startup that lessens after the car is driven. A mechanic suggested belt dressing, while a parts dealer advised against it. Experts recommend replacing the belts and checking tension instead of using dressing, and note that timing-belt replacement is typically due at 4 years or 60,000 miles.
