1987 Toyota Celica Ignition Timing
TURBO101
  • 8 POSTS
I have a 1987 Toyota Celica ST,with 156,xxx miles.its a 2.0L 4-cylinder FE engine.
My problem is that i set my ignition timing to 15 degrees and using 87 octane fuel.im wandering if i advanced it to much?Should i adjust it back to 10 degrees or leave it at 15 because im getting better mileage?Will it pass smog on 15 or set it to 10 then get it smog,then adjust back to 15?
Comments will be appreciatable.THANKS.
Turbo101.
May 5, 2007 at 5:33 PM
  • 75,988 POSTS
[quote:8f05789ce0="Turbo101"]I have a 1987 Toyota Celica ST,with 156,xxx miles.its a 2.0L 4-cylinder FE engine.
Turbo101.[/quote:8f05789ce0]
Good idea reset it before smog testing-too much advance can cause detonation and raising the oxides of nitrogen and EGR being blame for something its not doing.
May 5, 2007 at 8:41 PM
TURBO101
  • 8 POSTS
so should i leave it at 15 or adjust to 10 or 13?Which will be better?
Is 15 degrees putting detonation on my pistons??
May 6, 2007 at 11:30 AM
Suggested Repair
Reset base ignition timing to the factory specification before smog testing rather than leaving it advanced to 15 degrees. Excessive advance on 87-octane fuel can cause detonation and raise NOx, which can fail emissions testing.
Conversation Summary
The owner of a 1987 Toyota Celica ST with a 2.0L engine set ignition timing to 15 degrees on 87-octane fuel and asked whether that was too advanced, whether 10 or 13 degrees would be better, and whether it would pass smog. The expert advised resetting timing before smog testing, noting that too much advance can cause detonation and raise oxides of nitrogen.
